andys auto sport
Old 02-05-2010, 11:18 AM
ryans01z28 ryans01z28 is offline
Default 93 jimmy engine stalls out? common prob with these
the engine stalls out after it rus 4a while & i know this is common on these 4.3 vortecs but i replaced the spider assembly & it still does it. when i pulled the plentum its damp in there is the regulator lines bad? nothing else is in there to make it wet.
Old 02-05-2010, 03:19 PM
The other thing that can cause this is a bad fuel pressure regulator leaking gas, also a bad EGR valve or a faulty (IAC) Air Idle Control valve. Start with the simple and replace the fuel filter and clean the EGR and IAC with fuel injector cleaner. If the problem still there, do a fuel pressure drop test to see if your fuel pressure regulator is leaking. Good luck and keep us all posted, and hope it's as simple as cleaning the EGR or IAC.
Old 02-05-2010, 03:38 PM
Quote:
i put in a new spider assembly & regulator & injector came with it. the only other thing i could think of was the two lines that go to the regulator but i havent replaced them yet. ill do that after i put new bearings in the motor
  #4
Old 02-05-2010, 03:47 PM
Cool
Quote:
When you reinstalled the fuel lines, did you use oil on the connections not to damage the o rings. Keep us posted and good luck, those lines are also common to crack when they are moved around to much when replacing the SCPI.
vB code is On
