GMC Forum: AC compressor cycle on/off
Old 08-31-2010, 01:07 PM
afrohman afrohman is offline
Default AC compressor cycle on/off
When I turn the AC on in my 1996 GMC Yukon, the compressor cycles on but does not cycle off. Still blows ice cold air, just doesn't cycle off. I replaced the AC compressor, accumulator, pressure switch (that plugs into the accumulator) about a month ago.
Any advice?
Old 08-31-2010, 02:25 PM
Cool
Quote:
Any advice?
Hard to say what is wrong with it without any manifold gauge to see what your high and low readings are. Your system may just be a little low on R134a that it does not get high enough for the high side pressure switch to deactivate your compressor.
The best thing to do is to have your A/C system checked with a manifold gauge to get a high and low side readings.
Normal readings on high and low side with AC OFF (static pressure) – Depends on outside temperature, but normally is between 80-105 PSI
Normal low side reading with AC on high speed and MAX & engine at 800-1000 RPM’s – Ranges from 25-35 PSI
Normal high side reading ranges from 200-350 PSI
Good luck and keep us posted.
gmcowners.com recognizes that "GMC", it's logos and various model names and numbers are registered trademarks of the General Motors Corporation. These terms are used for identification purposes only. gmcowners.com is not affiliated in any way with the General Motors Corporation, GMC or any other company listed herein. All information on this site is the opinion of its members and not the opinion of the site itself. ©2014 Madison Ross Media Group. All rights reserved. Content published on GMCOwners.com requires permission for reprint.
