| GMC Yukon Forum Forum for discussions regarding the GMC Yukon |
Thread Tools |
i have seen a few forums with this question, but no clear cut answer. Seems pretty simple but don't want to cause any damage. My 2001 Yukon XL has spark plug wires with a metal shield. I am not sure how to remove the wires to get to the spark plug. All the wires are really tight. Do I remove the metal shield first? Or do they both come out together?
Quote:
Or after removing the metal shield first, you need to grip the boot at the plug insulator and twist and pull. There is a special tool that fits at the bottom of the boot http://www.harborfreight.com/spark-p..._source=nextag . Put silicon grease in the boots before you replace them and they won't stick next time. Here's the bulletin on the spark plug replacement and gap. Document ID# 1396703 Subject: Information on New Spark Plugs and Gapping #03-06-04-060 - (10/24/2003) Models: 2004 Buick Ranier 2002-2004 Cadillac Escalade, Escalade EXT 2003-2004 Cadillac Escalade ESV 2004 Cadillac CTS-V 1997-2004 Chevrolet Corvette 1998-2002 Chevrolet Camaro 1999-2004 Chevrolet Silverado 2000-2004 Chevrolet Suburban, Tahoe 2002-2004 Chevrolet Avalanche 2003-2004 Chevrolet Express, TrailBlazer 1999-2004 GMC Sierra 2000-2004 GMC Yukon, Yukon XL 2001-2004 GMC Yukon Denali, Yukon XL Denali 2002-2004 GMC Sierra Denali 2003-2004 GMC Envoy XL 1998-2002 Pontiac Firebird 2004 Pontiac GTO 2003-2004 Hummer H2 with 4.8L, 5.3L, 5.7L or 6.0L V-8 Engine (VINs V, P, T, Z, G, S, N, U -- RPOs LR4, LM4, LM7, L59, LS1, LS6, LQ9, LQ4) A new spark plug has been released for use in the above vehicles. The new spark plug has an Iridium tip instead of the current Platinum tip. Due to the different tip design, the gap of the spark plug has also changed. The new spark plug, P/N 12571164 with AC Delco P/N 41-985, is gapped to 1.01mm (0.040 inches) when the spark plug is made. The spark plug gap is set during manufacturing and should not be changed or damage to the spark plug may result. Any new spark plug found to not be properly gapped should not be used. GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information. WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION © Copyright General Motors Corporation. All Rights Reserved. Document ID# 1396703 Good luck and be safe.
| Thread Tools | |
