GMC Forum: 2003 gmc yukon denali antifreeze capacity?
Old 01-13-2011, 09:17 PM
MAXD MAXD is offline
Default 2003 gmc yukon denali antifreeze capacity?
Does anyone know how much antifreeze a 2003 gmc yukon denali will hold with a 6.0 liter motor?
__________________
Powered by Yahoo! Answers
Old 01-14-2011, 09:52 PM
Cool
Quote:
2003 GMC TRUCKS YUKON DENALI 6.0L 8-cyl Engine Code [U]
CAPACITIES:
Engine, with filter..........5.7 liters [1]
Cooling System, Initial Fill..........15 liters
DexCool Engine Coolant
Automatic Transmission, 4L60-E Initial Fill..........4.7 liters
Automatic Transmission, Total Fill 4 speed 4L60-E..........10.6 liters
Differential, Front..........1.7 liters
Differential, With 10.5 RingGear Dana Rear..........2.6 liters
Differential, With 10.5 RingGear EX D Rear..........3.1 liters
Differential, With 12 RingGear Rockwe Rear..........6.6 liters
Differential, With 8.5, 8-5/8 R Rear..........2 liters
Differential, With 9.5 RingGear Rear..........2.6 liters
Differential, With 9.75 RingGear Rear..........2.6 liters
[1] After refill check oil level.
Hope this helps and some.
Old 10-07-2011, 11:23 PM
Jamesdthomas2 Jamesdthomas2 is offline
I just did a coolant flush and I put about 13 qts. I know other manuals say about 24 quarts. I did a coolant flush with a garden hose too. so my block may have been full of water too. I added a little concentrated coolant to ofset this though.
  #4
Old 10-14-2011, 09:54 PM
Cool
Quote:
The concentration of antifreeze in the coolant needs to be checked prior to the onset of cold weather. A 50/50 mixture of antifreeze and water is recommended and will protect against freezing down to -34 degrees F and boilover protection to 263 degrees F.
For maximum protection, up to a 70% mixture of antifreeze can be used for freezing protection to -84 degrees F.
Noth: Do not use more than 70% antifreeze, and never run straight water in the cooling system because it offers no corrosion, freezing or boilover protection.
Pick up a prestone coolant/antifreeze tester and that should help you get your Coolant mixture right.
  #5
Old 10-15-2011, 06:31 AM
Z15 Z15 is offline
Diesel engines use about 25 qts., not any gas engine
If you put 13 qts of coolant in, you are nearly at 100%, big time problem. Anti-Freeze/coolant are design to be diluted with water and will not function at 100%.
Also note, some of these newer vehicles can't be flushed correctly just using a garden hose. Not sure about the 2003 though. You could create an air pocket in the system that could be extremely difficult to eliminate.
2003 GMC TRUCKS SIERRA 1500 PICKUP 6.0L 8-cyl Engine Code
Engine, with filter..........6.1 quarts [1]
Cooling System, AT With OCOOL Initial Fill..........14.8 quarts
Cooling System, MT With OCOOL Initial Fill..........14.8 quarts
Cooling System, With AT Initial Fill..........14.8 quarts
Cooling System, With MT Initial Fill..........15.3 quarts
Automatic Transmission, 4L65-E Initial Fill..........5 quarts
Automatic Transmission, 4L80-E Initial Fill..........7.8 quarts
4 speed 4L65-E..........11.3 quarts
4 speed 4L80-E..........13.6 quarts
Differential, Front..........3.6 pints
Differential, American 10.5 R Rear..........5.5 pints
Differential, American 8.5 RingGear Rear..........4.3 pints
Differential, American 8.6 RingGear Rear..........4.3 pints
Differential, With 11.5 RingGear Rear..........7.7 pints
Differential, With 9.5 RingGear AA Rear..........5.5 pints
Differential, With 9.75 RingGear Rear..........6 pints
Transfer Case, NVG 149..........4.5 pints
Transfer Case, NVG 236/246..........4.1 pints
Transfer Case, NVG 261/263..........4.1 pints
