GMC Forum: Replacing the starter on a 1995 GMC Jimmy (4 wheel drive)...?
Old 01-26-2011, 12:39 PM
maerik maerik is offline
Default Replacing the starter on a 1995 GMC Jimmy (4 wheel drive)...?
Will I have to loosen the motor mount and/or lift/tilt the motor to get to the starter?
__________________
Powered by Yahoo! Answers
Old 03-01-2011, 03:01 PM
Little Roober Little Roober is offline
Send a message via AIM to Little Roober
If you haven't already done this and figured it all out, You don't have to lift the engine. The starter is in there tight, but it will come out if you turn it right. It takes a while to figure it out, but you can do it.
Old 03-05-2011, 11:36 AM
wingzfan99 wingzfan99 is offline
I actually just did this a couple of weeks ago ('95 Jimmy SLT 4x4). No lifting of the motor required. Just patience.
First, you'll want to undo the wiring through the front passenger side wheel well... Mine has a flap cut in it to allow easy access but I don't know if that's a factory feature or not... lol.
Then, get underneath and look for the starter. There's a couple of support bars connected to the bell housing on the transmission -- you'll want to loosen them and move them out of the way. Then, you can loosen the bolts on the starter and try to wiggle it out.
There's also a removable heat shield on the starter that might get in the way and prevent you from taking it out... the shield comes off pretty easily.
Really, you'll probably spend half an hour to an hour wiggling the thing out of there and figuring out the right angles... but once it's out, putting the new one in takes about 5 minutes.
Also, I recommend not reconnecting the wiring until you have it in place and bolted down... it's fairly easy to do from the wheel well.
