andy's auto sport
Old 09-22-2011, 11:29 AM
Willstox Willstox is offline
Default 2001 Safari.4.3.....wont start
I posted once but never showed up? My question is.........do the safari's get vapor locked? My van ran fine, filled the tank up, went 5 miles down the road and it just shut down? It turns over just fine, I checked the fuel pump and it is fine, I turn the motor over and it just about starts but it wont? This happened once before and after trying to start it several times it finally started. What could be the cause of this? 2001 GMC 4.3 Safari.
Note: If I sit in the van, turn the key on several time's....to make sure the fuel pump is sending fuel......it almost starts???
Up date: I took the MAP sensor off and cleaned it, had to put the battery charger on it.....did not start...just makes no since how it will almost start???
UPDATE: I am getting a code...P1683....anyone know what these means and how to correct it?
Old 09-22-2011, 04:53 PM
sounds like lack of fuel pressure. Just becaues the pump runs does not mean you have fuel or fuel pressure.
Check the pressure with a gauge
Old 09-22-2011, 05:17 PM
How hard is it to change the fluid presure switch?
  #4
Old 09-22-2011, 07:26 PM
shadyowl2 shadyowl2 is offline
The code p1683 is an error in the ecm. The Eraseable programable read only memory in the computer. It can't read the data in the computer. That is the cause of the no start. The dealer must replace the computer and flash the new one
  #5
Old 09-22-2011, 07:38 PM
Thank you Shadyowl, thats what I was looking for.
Again, Thank you.
  #6
Old 09-25-2011, 06:00 PM
There is one other thing you could check too. Make sure your getting spark to the plugs. These 4.3's were also known for the dist cap's cross firing and causing a no start condition. That will tell you definately. This code is a known problem in the newer GM'S for no starts.
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
gmcowners.com recognizes that "GMC", it's logos and various model names and numbers are registered trademarks of the General Motors Corporation. These terms are used for identification purposes only. gmcowners.com is not affiliated in any way with the General Motors Corporation, GMC or any other company listed herein. All information on this site is the opinion of its members and not the opinion of the site itself. ©2012 Madison Ross Media Group. All rights reserved. Content published on GMCOwners.com requires permission for reprint.
GMC Parts at Andy's | GMC Sierra Tail Lights | GMC Sierra Headlights
