andy's auto sport
Go Back   GMC Forums > GMC Vehicles No Longer In Production > GMC Suburban Forum
GMC Suburban Forum Forum for discussions regarding the GMC Suburban
Old 02-19-2012, 09:24 AM
BLOCKHEAD454 BLOCKHEAD454 is offline
Unhappy Engine missing on cold mornings
I have a 1990 GMC Suburban 1/2 ton 350 tbi auto trans, V1500 on the vin. It just started giving me misses when I leave for work on the cold mornings this winter. It starts up fine, idles fine and I can rev up in park with no issues. After I put it into gear to go down the road if I hit the gas it misses bad. Sometimes sounds like multiple cylinders, sometimes sounds like one. I have noticed it will only do it when its less than 45 degrees outside in the morning. Will not do it on mornings that are like 50 deg and up. After sitting at work for 10 hours, it will not do it before I go home. After less than 3 minutes of run time it will not do it buy the time I hit the first turn off the highway thats only a half mile from home. After that small time frame it runs like a champ. It doesnt last long but first thing in the morning this pisses me off because it makes my nice duel exhaust sound like a sick dirt bike. I have checked and/or replaced the following,
Tps
IAC
Injectors
Fuel pressure reg
Vacummme system all hoses
Fuel lines
Fuel pump
Plugs
Wires
Distributer
Cap
Rotor
ECM
PROM
Fuses
Wires
Please don't say o2 senser, Its been replaced and even if it wasen't it doesent become active untill closed loop @ 900oF so it doesn't count. I have had every body say thats the problem.
So guys with all I've done is there anyone that can help and tell me what I've missed.
Old 02-19-2012, 11:04 PM
sounds like a coil... test it when it cold with a volt/oms meter. goggle specs for your year/model
Old 02-22-2012, 11:32 AM
dbutton1990 dbutton1990 is offline
did you check your timing?
  #4
Old 02-22-2012, 09:27 PM
how will the timing only be a problem under 45 degrees?
  #5
Old 02-23-2012, 09:48 AM
cedicol cedicol is offline
check the battery first an than the alternator. If the battery is getting low on juce you can have the same problem. Alternator as well. If the alternator dosn't gives enough juice te battery is getting low as well.
  #6
Old 03-30-2012, 10:36 PM
Ok. Now its getting worse. its spring time and now its doing it on mornings that are like 60 degrees out now. Coil is good and alternator voltage is good as long with battery draw and charge. Whats next fellas because its doing it now almost every morning.
  #7
Old 04-01-2012, 07:58 PM
well i would drop it off at a good repair shop/garage. Let them diag it for you. I know if i had it in front of me i would not need much time to find it if it's as bad as you say.
  #8
Old 04-01-2012, 10:59 PM
Well you sound like you're pretty confident in finding the issue. Problem is I've had it to an ASE certified shop and they had it for a week and ran it on a vac test, compression test and an ocilligraph and they couldn't figure it out. I myself am ASE cert and can't figure out this ghost in the machine. What have I overlooked.
  #9
Old 04-02-2012, 10:31 PM
well i can tell you this .. This is what i do best ASE master and GM master tech.
I belive your over looking something that you alrerady did or checked. Not uncomon to have a bad part.
Now what i want to know is
Does it have black smoke when this happens?
Have you check the data stream and looked at the temp sensor reading to see if it's correct?
Have you done a top engine cleaning pos valves sticking when cold. (happens)
You could hook up a nerd light to go in side of the cab to test injector pulse (done with jumper wires) so you know if they are or not pulsing when it happens.
Same with spark tester. Also does your tk have the est box that bolts on the right side of the intake manifold.
Answer these questions and i will [post again with more questions.
  #10
Old 04-04-2012, 11:24 AM
Thank you. I have the truck in a shop getting some paint work done to it and welding work. Once i get it back i will go through these suggestions one by one. As for the est, its on the passenger side of the manifold bolted to the same plate as the egr solenoid and the map sensor. And no the engine does not put out black smoke when it does the hit and miss. I have checked the push rods for deflection, set and checked all rockers and lock nuts to ensure I don't have a top end issue. The valves were checked when I sent the heads off for xray and to have them checked after i had a thermostat issue that caused a little overheating but no known damage to the block or heads. Head gaskets and manifold gasket are new.
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
gmcowners.com recognizes that "GMC", it's logos and various model names and numbers are registered trademarks of the General Motors Corporation. These terms are used for identification purposes only. gmcowners.com is not affiliated in any way with the General Motors Corporation, GMC or any other company listed herein. All information on this site is the opinion of its members and not the opinion of the site itself. ©2012 Madison Ross Media Group. All rights reserved. Content published on GMCOwners.com requires permission for reprint.
GMC Parts at Andy's | GMC Sierra Tail Lights | GMC Sierra Headlights
