GMC Forum: P0304 cylinder 4 misfire
Old 03-13-2012, 01:57 PM
shane.vattimo shane.vattimo is offline
Default P0304 cylinder 4 misfire
Alright folks here it goes. cylinder 4 on gmc jimmy has a bit of a misfire and a slight of a rough idle. hesitation bog down when i stomp the accelerator. its a 99. spider injector is fine, we have a bright blue arc off plug and new plug wires. i have put a hose from even side of motor to ear and it is one of the smoothest motors i ever heard, not tick knock ping or chatter. how much does anyone know about back pressure affecting cylinder 4 misfire, on that side of the motor there is a small dent in exhaust pipe before the "y". please help...this piece has consumed my weekends for to long as i work a lot and have 2 small kids and a home renovation going on. wits end folks. somebody save me.
Old 03-13-2012, 08:16 PM
any takers?
Old 03-13-2012, 09:16 PM
Cool
Quote:
Start with the simple and clean your throttle body and your AMF sensor. With a dirty AMF sensor, it can cause the issues your describing and would not hurt also to give your engine a http://www.seafoamsales.com/ treatment.
Good luck and keep us posted.
  #4
Old 03-20-2012, 09:11 AM
why is everyone all of the sudden trying to sell me seafoam. anyhew got crushed y pipe out runnin nothin but exhaust headers. back pressure is not the issue. wish it was. not plugs wires or injectors....i guess i gotta do like the rest of the schmucks and start swapping parts, which we know can get expensive. also distributor gear looks absolutley beautiful.
  #5
Old 03-20-2012, 12:08 PM
cylinder 4 at 30 psi wet or dry.
  #6
Old 03-20-2012, 09:20 PM
VALVE NOT SEATED PROPERLY! pulled the head stuck a vacuum to the valve and watched smoke pull in through intake port.
  #7
Old 03-27-2012, 07:56 AM
70.00 in gaskets 80.00 in junkyard heads and she is runnin better then evr.
Tags
cylinder 4., p0304, po304
