GMC Forum: 1995 Gmc Jimmy Stalling And Rough Idle, Gas Gusseler?
Old 05-09-2009, 10:07 AM
Marissa Marissa is offline
Default 1995 Gmc Jimmy Stalling And Rough Idle, Gas Gusseler?
MY 1995 GMC JIMMY SLT IS HAVING TROUBLE WITH THE IDLE AND ITS STALLING, WE JUST PUT IN NEW ERG VALVE AND CLEANED OUT ALL CARBEN, WELL OF WHAT WE COULD SEE ANYWAYS, AND A COUPLE OTHER THINGS BUT IM NOT SURE WHAT IT IS, AND ITS STILL SUCKING UP GAS AND STALLING AND ITS JUST NOT DOING VERY WELL, PLEASE GIVE ME ANYTHING WE CAN CHECK OR WHAT THE PROBLEM MIGHT BE.
we already changed the feul pump and filter and changed the oil, and the spark plugs, the trottle positioning sensor, and we put in a gas treatment and octane booster, and the injector cleaner. and it still is messing up on us.
__________________
Powered by Yahoo! Answers
Old 02-17-2012, 01:04 PM
Kdurham Kdurham is offline
Minne is doing the exact same thing, its a 2000, by chance is your fuel guage misreadind sating empty ehen full,.full when empty,
Old 02-17-2012, 09:22 PM
listen some times you just need a pro to diag it for you. like in this case throwing parts at it and it's still not fixed. Parts add up fast!
now what you should do is go to a Good repair shop and have it diag for a hour or sometimes two hours labor then go home and fix it your self.
this would be cheeper than replacing parts plus if you have a wiring problem then you will never fix it !
Good luck
  #4
Old 02-17-2012, 10:42 PM
ferretx9 ferretx9 is offline
What condition are the Distributor cap , Plug Wires & Air filter in ?
Have you checked vacuum lines for cracks / leaks ?
Have you tried running Seafoam thru it ?
