andy's auto sport
Old 09-04-2009, 10:38 PM
tigger tigger is offline
Default 1994 gmc jimmy no spark problem?
i have a 94 gmc jimmy 4x4 the coil pack is sending spark to the disributor but no sparkis coming out of the cap or plug wires i have replaced all the wires the cap the rotor and have put in 2 differnt disrubutors they were both from a used auto parts place but what are the chances of 2 being bad also everything is pointing to the pick up coil also the ignition modual is good all ready tested all fuses good unless there is a in line fuse what elsle could there be please help its been 5 days im out of options
__________________
Powered by Yahoo! Answers
thebax2006 thebax2006 is offline
If you have spark going into a distributor cap and no spark coming out you have a problem with the rotor or cap contact to the rotor. If the rotor is a resistance rotor check the ohm reading from the tip to the center contact point in the middle of the rotor.
__________________
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
gmcowners.com recognizes that "GMC", it's logos and various model names and numbers are registered trademarks of the General Motors Corporation. These terms are used for identification purposes only. gmcowners.com is not affiliated in any way with the General Motors Corporation, GMC or any other company listed herein. All information on this site is the opinion of its members and not the opinion of the site itself. ©2012 Madison Ross Media Group. All rights reserved. Content published on GMCOwners.com requires permission for reprint.
GMC Parts at Andy's | GMC Sierra Tail Lights | GMC Sierra Headlights
