GMC Forum: help help 1995 gmc sierra ignition switch.
Old 12-29-2009, 05:53 PM
metalman_smi metalman_smi is offline
Default help help 1995 gmc sierra ignition switch.
can someone help me i got to change my ignition switch on my 1995 gmc with driverside airbag. Any helpful hints befor i get started! thx
Old 01-03-2010, 12:27 AM
Someclown Someclown is offline
This is for 98 should be the same
Disconnect the battery negative cable.
Disable the SIR system. Refer to Disabling the SIR System in SIR.
Position the steering wheel half way between the upper and lower tilt stops.
Remove the steering wheel. Refer to Steering Wheel Replacement .
Roll back the shift lever seal from the upper and the lower shrouds.
Remove the 2 TORX screws from the lower steering column shroud.
Remove the lower steering column shroud.
Remove the 2 TORXscrews from the upper steering column shroud. Refer to Steering Column Shrouds - Disassemble or Steering Column Shrouds - Disassemble Floor Shift .
Lift the upper steering column shroud to gain access to the lock cylinder access hole.
Using a bent tip awl, insert the tip into the ignition lock cylinder access hole.
Turn the ignition lock cylinder to the START position. Using the bent tip awl, push down on the ignition lock cylinder retaining pin.
Release the ignition lock cylinder to the RUN position.
Remove the ignition lock cylinder from the lock module assembly by pulling the ignition lock cylinder away from the steering column.
Installation Procedure
Insert the ignition lock cylinder through the upper shroud.
Install the ignition lock cylinder to the lock module assembly by doing the following:
Align the positioning slot and locking tab slot on the lock module assembly to the positioning tab and locking tab on the ignition lock cylinder.
Push the ignition lock cylinder into the lock module assembly until the locking tab locks against the locking tab.
Install the 2 TORXscrews to the upper shroud. Tighten
Install the lower shroud. Refer to Steering Column Shrouds - Assemble or Steering Column Shrouds - Assemble Floor Shift .
Install the shift lever seal to the upper and the lower shrouds.
Install the steering wheel. Refer to Steering Wheel Replacement .
Enable the SIR system. Refer to Enabling the SIR System in SIR.
Connect the battery negative cable.
Perform the Passlock learn procedure. Refer to PASSLOCK Reprogramming Seed and Key in Theft Deterrent.
