gmc forums   gmc forums
Go Back   GMC Forums > GMC Vehicles No Longer In Production > GMC Jimmy Forum
Advertisements
gmc hummer ev forums
GMC Jimmy Forum Forum for discussions regarding the GMC Jimmy
GMC Forum: 1999 Jimmy Crank No Start
Reply
Thread Tools
  #1
Old 06-05-2019, 11:30 AM
Earthvillager Earthvillager is offline
Junior Member
Drives a GMC Truck
Default 1999 Jimmy Crank No Start
4.3 Vortex engine.I hope someone here found a solution for this problem! I was driving when it just shut down in Houston traffic! Oh joy! No catastrophic sounds, oil pressure was around 45psi, water temp normal, voltage at 14.2 according to the gauges at the time of occurrence I ran the following tests and found: Checked and verified all fuses and relays operational, I ran the Pass Lock reset just to be sure Security light went off normally before and after test, have 60 psi fuel at the sharder valve, good spark at the end on the spark plug wires, rotor points to #1 at TDC, compression sounds good (not gauge tested yet), power at the injector gang plug, MAF is within voltage specs, had a P0800 code but MAP tested good, cleared code it did not return upon cranking. Will not fire even with starting fluid. Been on this for three days straight! We're having to rent a car as this is our only vehicle atm and that budget is reaching its end. Desperate to find a solution!!! Please help!
  #2
Old 06-06-2019, 12:54 PM
Junior Member
Drives a GMC Truck
Default
Found the problem. Ran compression test Zero psi on number one... too heart sick to test the rest at this point.
  #3
Old 02-09-2020, 04:19 PM
bmwrider2012 bmwrider2012 is offline
Junior Member
Drives a GMC Truck
Default
I've got the exact same problem on my 1999 Jimmy; difference being mine started after while. Same thing happened a few days later. Right now it's running. I'm going to run the same diagnostics you did.
However, I doubt a single dropped cylinder will cause those symptoms. It may be hard to start and run like crap, but it won't suddenly stop while you're driving it. I've lost two cylinders on my 97 Tahoe, it runs like crap and is hard to start, but runs OK at steady speeds. If I find anything else, I'll let you know.
Reply
Tags
fuel, no start, spark
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2020, vBulletin Solutions Inc.
