gmc forums   gmc forums
Go Back   GMC Forums > GMC Vehicles No Longer In Production > GMC Jimmy Forum
Advertisements
cars connected social network
GMC Jimmy Forum Forum for discussions regarding the GMC Jimmy
GMC Forum: Crossbar over the transmission pan?
Reply
Thread Tools
  #1
Old 02-18-2019, 12:31 AM
justus.rhines@gmail.com justus.rhines@gmail.com is offline
Junior Member
Drives a GMC Truck
Default Crossbar over the transmission pan?
I have a 98 GMC Jimmy. Trying to do service on the tranny but there is a large black bar covering the last 3 bolts in the fluid pan. I belive this bar is the crossmember but not sure. If i take the bar out will i need to jack the tranny up or is there a trick to get these last few bolts out?
  #2
Old 02-24-2019, 05:00 PM
larryderouin's Avatar
larryderouin larryderouin is offline
Junior Member
Drives a 2013 GMC YUKON XL
Default
You need to remove the frame bolts on the Crossmember and the tranny mount bolts under the tailshaft, jack up the trans slightly to take the weight off the crossmember, then slide it back so you can drop the pan. Install is reverse of removal. Suggest installing a drain valve in the pan. Makes it less messy when changing fluid.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Looking for something a little sporty? Believe it or not, Kia may have something for you. The Kia Stinger is a large sport-oriented hatchback sedan in the mold of the Audi A7.
