Go Back   GMC Forums > GMC Vehicles Currently In Production > GMC Acadia Forum
Advertisements
GMC Acadia Forum Forum for discussions regarding the GMC Acadia
GMC Forum: 2007 GMC Acadia - 3.6L Valve Cover Gasket Replacement DIY
Old 11-02-2015, 07:23 PM
Schmederling Schmederling is offline
Drives a
Default 2007 GMC Acadia - 3.6L Valve Cover Gasket Replacement DIY
Hello All,
I am looking for a DIY or Vid on replacing the Valve Cover Gaskets on a 2007 GMC Acadia 3.6L.
I was replacing the plugs today & noticed oil in the Spark-Plug tubes & suspect it's the actual spark-plug tube seal or gasket & need to remove the VCG first so will be replacing that as well.
I am stuck as one of the bolts on the VC seems to not be accessible while all others are, the one bolt is under the lower intake manifold - looking for a DIY please or Pic's of the entire process please. I cannot find anything on-line.
Click image for larger version
ID:	486   Click image for larger version
ID:	487   Click image for larger version
ID:	488   Click image for larger version
ID:	489   Click image for larger version
Old 11-02-2015, 07:28 PM
Drives a
Here are a few more pic's
ID:	491   Click image for larger version
Old 11-02-2015, 09:32 PM
Drives a
any help here with a DIY with Pic's or a Vid would be great!!
Please & thanks
  #4
Old 11-09-2015, 04:47 PM
Parts007 Parts007 is offline
Drives a
You did not specify what side valve cover you are stuck on. But looking at the procedure for the left valve cover, it states the following;
remove upper intake
remove lower intake
remove coils
remove the power steering bracket
  #5
Old 04-07-2016, 11:23 AM
hungtdao hungtdao is offline
Drives a
I believe he talked about the right side valve cover which is located in rear where nut/bolt are hard to reach. He seemed stuck on one bolt under the lower intake manifold.
Copyright ©2000 - 2019, vBulletin Solutions Inc.
gmcowners.com recognizes that "GMC", it's logos and various model names and numbers are registered trademarks of the General Motors Corporation. These terms are used for identification purposes only. gmcowners.com is not affiliated in any way with the General Motors Corporation, GMC or any other company listed herein. All information on this site is the opinion of its members and not the opinion of the site itself. 2017 Madison Ross Media Group. All rights reserved. Content published on GMCOwners.com requires permission for reprint.
Looking for something a little sporty? Believe it or not, Kia may have something for you. The Kia Stinger is a large sport-oriented hatchback sedan in the mold of the Audi A7. The Kia Telluride is a mid-size SUV similar to the BMW X5...
