gmc forums   gmc forums
Go Back   GMC Forums > GMC Vehicles No Longer In Production > GMC Safari Forum
Advertisements
cars connected social network
GMC Safari Forum Forum for all discussions relating to the GMC Safari passenger van
GMC Forum: 2001 Safari.4.3.....wont start
Reply
Thread Tools
  #1
Old 09-22-2011, 11:29 AM
Willstox Willstox is offline
Junior Member
Drives a
Default 2001 Safari.4.3.....wont start
I posted once but never showed up? My question is.........do the safari's get vapor locked? My van ran fine, filled the tank up, went 5 miles down the road and it just shut down? It turns over just fine, I checked the fuel pump and it is fine, I turn the motor over and it just about starts but it wont? This happened once before and after trying to start it several times it finally started. What could be the cause of this? 2001 GMC 4.3 Safari.
Note: If I sit in the van, turn the key on several time's....to make sure the fuel pump is sending fuel......it almost starts???
Up date: I took the MAP sensor off and cleaned it, had to put the battery charger on it.....did not start...just makes no since how it will almost start???
UPDATE: I am getting a code...P1683....anyone know what these means and how to correct it?
  #2
Old 09-22-2011, 04:53 PM
happy 2011 happy 2011 is offline
Senior Member
Drives a
Default
sounds like lack of fuel pressure. Just becaues the pump runs does not mean you have fuel or fuel pressure.
Check the pressure with a gauge
  #3
Old 09-22-2011, 05:17 PM
Junior Member
Drives a
Default
How hard is it to change the fluid presure switch?
  #4
Old 09-22-2011, 07:26 PM
shadyowl2 shadyowl2 is offline
Junior Member
Drives a
Default
The code p1683 is an error in the ecm. The Eraseable programable read only memory in the computer. It can't read the data in the computer. That is the cause of the no start. The dealer must replace the computer and flash the new one
  #5
Old 09-22-2011, 07:38 PM
Junior Member
Drives a
Default
Thank you Shadyowl, thats what I was looking for.
Again, Thank you.
  #6
Old 09-25-2011, 06:00 PM
Junior Member
Drives a
Default
There is one other thing you could check too. Make sure your getting spark to the plugs. These 4.3's were also known for the dist cap's cross firing and causing a no start condition. That will tell you definately. This code is a known problem in the newer GM'S for no starts.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2019, vBulletin Solutions Inc.
