Go Back   GMC Forums > GMC Vehicles No Longer In Production > GMC Safari Forum
Advertisements
cars connected social network
GMC Safari Forum Forum for all discussions relating to the GMC Safari passenger van
GMC Forum: GMC Safari Wont Start -- Simple Troubleshoot Steps?
Old 12-05-2012, 11:46 PM
crosis38 crosis38 is offline
Drives a
Question GMC Safari Wont Start -- Simple Troubleshoot Steps?
We just obtained a used 2000 GMC Safari SLT (4.3L V6).
When we go to start the car it does crank but it just wont start. The weather condition makes no difference. There is no service light that i can see. I do see a check engine light vut when i connected a $300 OBD2 scantool it reported not DTC codes.
I really would like to understand and troubleshoot this starting issue. Can someone please provide me the list of steps on how to troubleshoot this issue FROM simplest to most advanced procedure; obviously i would like to replace a fuse or spark plug FIRST before having to deal with replacing a rusted on fuel pump.
Some have said to test the fuel pressure. How exactly do i accomplish this?
Thanks
Old 12-06-2012, 07:52 PM
Drives a
simple
Check spark- If none diag
If you have spark check fuel- none diag
If you have fuel check pressure- if low diag
If pressure is ok check injector pulse- none diag
You need 4 things for a motor to run
1 compression - you can hear this while cranking
2 spark
3 fuel
4 exhaust
good luck
Old 12-06-2012, 10:56 PM
Drives a
Thanks happy.
The problem was no spark. i had to replace the distributor cap, rotor, and ignition coil. It finally started.
Thanks
Copyright ©2000 - 2019, vBulletin Solutions Inc.
gmcowners.com recognizes that "GMC", it's logos and various model names and numbers are registered trademarks of the General Motors Corporation. These terms are used for identification purposes only. gmcowners.com is not affiliated in any way with the General Motors Corporation, GMC or any other company listed herein. All information on this site is the opinion of its members and not the opinion of the site itself. 2017 Madison Ross Media Group. All rights reserved. Content published on GMCOwners.com requires permission for reprint.
Looking for something a little sporty? Believe it or not, Kia may have something for you. The Kia Stinger is a large sport-oriented hatchback sedan in the mold of the Audi A7. The Kia Telluride is a mid-size SUV similar to the BMW X5...
