Advertisements
cars connected social network
GMC Forum: "Multiple misfire on plugs." Code when Ck eng light
Old 06-15-2018, 10:51 AM
MartyDufrene MartyDufrene is offline
Drives a GMC Truck
Default "Multiple misfire on plugs." Code when Ck eng light
I bought the truck a few years ago. I changed the plugs,wires and rotor n distributor cap. Through out the last year annd a half I had changed wires a 2nd time shrting and also coil wire shorting so i replaced wire. with all that shorting most likely culprit now would be the poor coil right? Would the low fire level set the computer off. Im getting 80 miles to a tank..nightmare
Old 06-25-2018, 03:49 PM
OnlySonoma's Avatar
OnlySonoma OnlySonoma is offline
Member
Drives a 1995 GMC Sonoma SLS Extended Cab 4.3L V6 TBI RWD
The next thing I would replace is the Coil.
Story Time:
When the coil on my Sonoma was on its way out, it would still work but it would also arc a big spark to the closest piece of metal. I noticed it one day while it was dark out and I was looking in to the engine bay. The arc was about 1 to 2 inches long and was very bright. It also made a slight ticking noise, which i believe was the sound of it arcing. The engine still ran, but would misfire.
Old 10-29-2018, 05:48 PM
dirtygirls96stillrollin dirtygirls96stillrollin is offline
Drives a 96 GMC Jimmy 4.3 , 02 WJ 4.7, 11 Pathfinder 5.6
I ran E3 spark plugs one time and my Jimmy didn't even want to run. I have to use OEM/ACDelco plugs and wires.
Tags
multiple misfire code
Copyright ©2000 - 2019, vBulletin Solutions Inc.
gmcowners.com recognizes that "GMC", it's logos and various model names and numbers are registered trademarks of the General Motors Corporation. These terms are used for identification purposes only. gmcowners.com is not affiliated in any way with the General Motors Corporation, GMC or any other company listed herein. All information on this site is the opinion of its members and not the opinion of the site itself. 2017 Madison Ross Media Group. All rights reserved. Content published on GMCOwners.com requires permission for reprint.
Looking for something a little sporty? Believe it or not, Kia may have something for you. The Kia Stinger is a large sport-oriented hatchback sedan in the mold of the Audi A7.
