gmc forums   gmc forums
Go Back   GMC Forums > GMC Vehicles Currently In Production > GMC Yukon Forum
Advertisements
GMC Yukon Forum Forum for discussions regarding the GMC Yukon
GMC Forum: 2017 Yukon Denali stalls after refueling
Reply
Thread Tools
  #1
Old 07-15-2019, 07:40 PM
jim Hay jim Hay is offline
Junior Member
Drives a 2007 GMC Yukon Denali
Default 2017 Yukon Denali stalls after refueling
My GMC was working fine until I added a half tank of alcohol free gas. Within five minutes it sputtered and stalled while idling. Yellow warning lights and traction lights lite up. Restarted but had to keep idle high to prevent stalling. Stumbled to my auto repair shop. Codes show misfires on cylinder six. Does this sound like clogged fuel injector from bad gas?
  #2
Old 07-16-2019, 10:55 AM
larryderouin's Avatar
larryderouin larryderouin is offline
Junior Member
Drives a 2013 GMC YUKON XL
Default
More likely a fouled plug. Pull the plug, and have the shop take a look. the insulator in the middle should be intact and a light brown color. Gap should be about .040" to .060" depending on Engine (its in the manual) . A cracked or broken insulator will cause the plug to misfire. REPLACE IT.
  #3
Old 07-22-2019, 08:24 PM
Smokin' Denali Smokin' Denali is offline
Senior Member
Drives a
Default
my opinion.....too coincidental that it happened right after fill up. The alchohol gas didnt have long enough to be problem in even a NON compatible motor. Diagnostic will show a random cylinder even w a few misfiring, in my experiences. Change fuel filter. Bet theres WATER in it! But pilling thatb plug cant hurt either....
Alternate: My 2015 Yukon Denali (6.2L) recently did exact same thing!! Made a turn at light and it seemed like I was running on 3 cylinders! Had to rev very high to move to side of road even!! Onstar diagnosis requested immediately by me ( Blue Button) They said all kinds of thigs..." all intake/exhaust restricted, engine midfire on 4 cylinders..." Had to be towed to shop. Results: a valve spring had cracked, ruined push rod, piston, connecting rod, and few more things!! W 47K iles it was totally covered by GM Basic 50K miles/5 years powertrain waranty. Total upper head rebuild w gaskets , a/c charge, more!! Runs better than ever after 1 month now!!
good luck!
  #4
Old 07-26-2019, 01:15 PM
Junior Member
Default Alternate Theory is correct
After changing the fuel injector for cylinder six with no improvement the shop took off the valve cover and discovered a broken exhaust valve spring for cylinder six. Fortunately, it did not do any other damage. Purely a coincidence that I had just added gas. They did not charge me for the fuel injector. I did use pure gas not the 10% ethanol gas so it was less likely to be water-related anyway.
Thanks to everyone for the feedback.
  #5
Old 11-20-2019, 11:29 PM
Senior Member
Drives a
Default
WOW! u lucked out! See my story above. This does NOT look good for these 6.2 L engines. Hope yours was covered under waranty also!
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2019, vBulletin Solutions Inc.
