gmc forums   gmc forums
Go Back   GMC Forums > GMC Vehicles No Longer In Production > GMC Jimmy Forum
Notices
GMC Jimmy Forum Forum for discussions regarding the GMC Jimmy
GMC Forum: 1977 Jimmy not starting after the accelerator cable broke and the gas almost ran out
Reply
Thread Tools
  #1
Old 09-28-2016, 11:45 PM
77Jimmy 77Jimmy is offline
Junior Member
Drives a GMC Truck
Question 1977 Jimmy not starting after the accelerator cable broke and the gas almost ran out
Hello,
what can I do for my GMC to start again. It stopped while running but the meter still had about an 1/8th of gas and then filled up gas about 5 gallons and when trying to start again pressing on the accelerator pedal the cable ripped or broke. I replaced it and now it doesn't start. I got one that seems a little longer than the one that was there. It has a 350 block edelbrook engine and carburetor I think it is a 5.7 engine. So the guys at Napa told me that was the cable for it. I had to pull it to my house because it didn't start. It stalls and then smells like gas but it doesn't start. I put zip ties on the end of the pedal because the cable seemed loose. Also the battery went weak after several attempts to start. I passed current to it from another car with jumper cables until it sounded like it usually does when trying to start but the engine won't start.
Any help or advice will be appreciated.
  #2
Old 06-11-2017, 01:04 PM
shaynehardy shaynehardy is offline
Member
Drives a
Default
the cable should be about 82 inches long, i would take that one off and measure it, if its the same length then replace the mechanical fuel pump, you will need to know if its 3 hose or 2 hose should be mounted on engine block
Click image for larger version
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertisements
suspension parts, shocks, struts and more
cars connected social network cars connected social networking app for ios cars connected social networking app for android
Copyright ©2000 - 2017, vBulletin Solutions Inc.
Looking for something a little sporty? Believe it or not, Kia may have something for you. The Kia Stinger is a large sport-oriented hatchback sedan in the mold of the Audi A7.
