suspension parts, shocks, struts and more
cars connected social network
GMC Forum: 07 Yukon xl Denali trans cooler
Old 11-29-2017, 02:49 PM
chucks chucks is offline
Drives a
Default 07 Yukon xl Denali trans cooler
My transmission lines are leaking going to the cooler. I wanted to replace them with upgraded fittings. My question is do the cooler lines need to run through the radiator or can I get a better cooler and bypass the radiator all together? I don't understand the purpose of running g hem through the radiator if you have a cooler?
Old 02-12-2018, 12:11 AM
Paul Sebesta Paul Sebesta is offline
Drives a GMC Truck
You can bypass the radiator but you need to make SURE that the cooler that you install is sufficient to keep the fluid cool. The reason that the lines run through the radiator and then the cooler is simply that when the vehicle is coming down the assembly line, all of them have lines that go to the radiator. The only difference being that on vehicles with a Towing Package or Heavy Duty Cooling Option (same thing, different names) the lines are added to route the fluid through the auxiliary cooler. The fluid only goes through the transmission auxiliary cooler when the temp of the fluid returning to the trans pan is too high and more cooling is necessary. I hope this helps. Btw, I write service manuals for GM and I am giving you reliable information.
Copyright ©2000 - 2018, vBulletin Solutions Inc. recognizes that "GMC", it's logos and various model names and numbers are registered trademarks of the General Motors Corporation. These terms are used for identification purposes only. is not affiliated in any way with the General Motors Corporation, GMC or any other company listed herein. All information on this site is the opinion of its members and not the opinion of the site itself. ©2017 Madison Ross Media Group. All rights reserved. Content published on requires permission for reprint.
Looking for something a little sporty? Believe it or not, Kia may have something for you. The Kia Stinger is a large sport-oriented hatchback sedan in the mold of the Audi A7.
