Advertisements
cars connected social network
GMC Forum: 2004 Yukon front end vibrates when stopping
Old 12-09-2017, 11:06 AM
Converseguy Converseguy is offline
Drives a GMC Truck
Default 2004 Yukon front end vibrates when stopping
I have a 2004 GMC Yukon Denali 23,000 orig miles, that when I stop I get a lot of vibration in the front end.
I have had the pads replaced and rotors turned. Front end components are all tight . Tires balanced.
Any thoughts ?
Old 12-17-2017, 09:13 AM
Daddio Daddio is offline
Drives a 2014 GMC Yukon, 2005 Lincoln LS, Massey Ferguson 165, 1956 Thunderbird, 1959 Cadillac Biarritz
It may simply be the brake shop didn't torque the wheel nuts properly. I had a similar issue, so I loosened the 6 nuts, then torqued them to 100 ft lb in the correct sequence, then 140 ft lb in same sequence. The correct sequence on a 6 stud wheel is 1-4-6-3-5-2. If this doesn't help it may be a defective front hub.
Old 02-12-2018, 12:01 AM
Paul Sebesta Paul Sebesta is offline
Drives a GMC Truck
Based on 13 years old and only 23K miles, I can just about guarantee the rotor cooling fins are corroded big time. Resurfacing the rotors removes material and if the cooling fins are in fact corroded, these rotors will forever pulsate. Time to replace the rotors NOT resurface (turn) them.
Copyright ©2000 - 2018, vBulletin Solutions Inc.
gmcowners.com recognizes that "GMC", it's logos and various model names and numbers are registered trademarks of the General Motors Corporation. These terms are used for identification purposes only. gmcowners.com is not affiliated in any way with the General Motors Corporation, GMC or any other company listed herein. All information on this site is the opinion of its members and not the opinion of the site itself. 2017 Madison Ross Media Group. All rights reserved. Content published on GMCOwners.com requires permission for reprint.
Looking for something a little sporty? Believe it or not, Kia may have something for you. The Kia Stinger is a large sport-oriented hatchback sedan in the mold of the Audi A7.
