gmc forums   gmc forums
Go Back   GMC Forums > GMC Vehicles No Longer In Production > GMC Safari Forum
Advertisements
GMC Safari Forum Forum for all discussions relating to the GMC Safari passenger van
GMC Forum: 2001 Safari 4.3 ...update
Reply
Thread Tools
  #1
Old 09-28-2011, 09:06 PM
Willstox Willstox is offline
Junior Member
Drives a
Exclamation 2001 Safari 4.3 ...update
update.: I have yet to do anything to the van.......simply because I've been layed off and Im scared to spend money but.....I went out to the van today and just for the heck of it I tryed to start it and sure enough it fired right up, took it around the block and it did fine, pulled it into the drive way and it acted as if it was getting no gas??? sputtering and such, also I noticed a real strong order....like rotten egg's....like a bad battery but it was coming from the tail pipe. I am thinking if the computer is bad, it could of just been a fluke and started and the computer no doing it's job with emmision's is the cause of the smell? Now it act's like it want's to start but wont......fuel filter? I had the codes cleared and no codes are showing right now? Any thought's?...Will
p.s. I did replace the crank sensor (because that was the code I got ) then the P1683 code showed up after I changed it??
  #2
Old 09-29-2011, 05:39 AM
Molson02536 Molson02536 is offline
Senior Member
Drives a
Send a message via AIM to Molson02536 Send a message via Yahoo to Molson02536
Cool
Its a PCM internal error fault. Make sure all your grounds are clean and tight and the PCM Connectors aren't full of water, then have the PCM put in for testing.
The other thing you may want to try is have your ICM checked also, i know it's a shot in the dark. But it could be as simple as that also.
Good luck and keep us posted. PS, its free to have your ICM tested at Auto Zone or Parts Source.
Molson02536
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2020, vBulletin Solutions Inc.
