gmc forums   gmc forums
Go Back   GMC Forums > GMC Vehicles Currently In Production > GMC Yukon Forum
Advertisements
cars connected social network
GMC Yukon Forum Forum for discussions regarding the GMC Yukon
GMC Forum: 2004 Denali 6.0 Dual radiator fan Install
Reply
Thread Tools
  #1
Old 07-11-2018, 12:22 PM
Converseguy Converseguy is offline
Junior Member
Drives a GMC Truck
Default 2004 Denali 6.0 Dual radiator fan Install
my Daughter has a 2004 GMC Denali 1500 XL with a 6.0 gas engine. She has always complained the AC does not cool at idle. Realizing it was a air flow issue. I install a dual fan system. I removed the old mechanical fan and clutch. Purchased a dual fan assembly from Rock Auto .Part number GPD 2811689 $119 plus tax. $18.98 Shipping. Ordered from Amazon Prime a Dewhel Aluminum Black Water Temp Meter Gauge Joint Pipe Sensor Adapter. $9.99 no shipping cost. Also ordered ordered 2 Ac Delco PT2649 Fan connectors $33.36. Last I ordered from Amazon prime a Hayden 3654 Adj Thermostic Fan Controler for $41.31.Do not use a Hayden 3651.
Remove Plastic Radiator top cover all push pins.
Remove Upper fan cover.
Remove Fan and Fan clutch.
Remove Lower Fan Cover.
Install new fan assembly . Perfect fit and uses orignal fan shourd bolts.
Very cold air at idle now 600 rpm's
wanted to attach photos but this would not let me. Files too big
  #2
Old 07-11-2018, 12:43 PM
Junior Member
Drives a GMC Truck
Default
Each fan draws less than 10 amps. Was not sure what amps the fan draw so I inserted fuses to see what the fan would run on. Installed a 10 amp fuse and ran with no issue.
  #3
Old 07-17-2018, 06:36 PM
Junior Member
Drives a GMC Truck
Default
Do not use a Hayden 3651 fan controller. Failed second day in service. Bad crimpted fuse connections and controller over heated on 20 amps service
  #4
Old 07-17-2018, 06:46 PM
Junior Member
Drives a GMC Truck
Default
Do not use a Hayden 3654 controler either piece of junk also. ended up hard wireing two 40 amp relays.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Looking for something a little sporty? Believe it or not, Kia may have something for you. The Kia Stinger is a large sport-oriented hatchback sedan in the mold of the Audi A7.
