Hi all!
I've been having a hard time diagnosing an issue with our 99 Yukon. A few months ago I was going 65 down the interstate and it straight shut off on me. I pulled into the shoulder, put it in park, took the key out, then tried to restart it. No clicking, no turning, nothing. We had it towed back to the house and I started going through everything ignition wise. The battery was dead, but recharged fine. I replaced just about everything except the alternator and starter which tested fine at Auto Zone. So new ignition switch, module and coil, spark plugs, wires, cap and rotor, the works. The rotor was worn pretty bad and miraculously after replacing that, the Yukon ran, though it was rough. It would shake like it was missing during idle and sure enough pulled a code for cylinder 2 misfiring. Then, the missing stopped. For about 2 weeks it ran fantastic.
Now, I was trying to back out of the driveway and it died again. Straight shut off. I put it in park, took the key out, tried to start it up again and I got clicking, the radio turning on and off and an array of strange clicking noises coming from the steering column. The next time I keyed over I got absolutely nothing. The third time, it started and I was able to pull back in the driveway completely. I shut it off and came back to it later to find the battery completely drained.
I've got the battery recharging now, but I'm completely at a loss. I don't even know where to begin. I pulled all the fuses out and they LOOKED fine but I was told the best place to start is to take a test light to each one to find which system is faulty. Is it possible this could be the computer?
Has anyone had a similar problem or have any idea what could possibly be going on?
Thanks for any and all help!!!
