Vehicle: 2000 Jimmy 4x4
Millage: 89,000
Engine: 4.3
Trans: Auto
I am experiencing acceleration problems, on a cold start the truck will bog out while the RPM's will race. This also happens hot or cold from a stop, from the stop the RPM's race but the truck has no acceleration. Once moving this is not a problem but the acceleration is still week and it takes some effort to get to passing speed.
Then sometimes I have no problems at all.
Along with this the a/c & heater have issues also. I know that the climate control (analog) has a vacuum leak coming from the selector dial (if you turn it a defrost it just continues to blow through the vents). If I turn off the a/c the acceleration is slightly better but even off the a/c will still blow very lightly.
I am pretty sure this is not a catalytic converter problem, I have experienced them before and this is not the same.
I still get decent millage around 16 so I am pretty sure this IS NOT A FUEL PROBLEM.
I had one person tell me it is the vacuum leak that is causing this problem.
And yes my gas gauge does not work just like ever Jimmy out there.
Please DO NOT reply asking what codes it is throwing because I don't have a scanner nor do I have access to one.
Thanx.
Millage: 89,000
Engine: 4.3
Trans: Auto
Thanx.
