chuckg101 chuckg101 is offline
I'm having problems with my 01 jimmy sls I've replaced plugs wires fuel filter cleaned maf sensor changed cam sensor and throttle position sensor. I've also cleaned the the throttle body out. It still sputters while cruising but it idles fine. Could anyone help me here? Also when I shift gears the rpms jump up 300 rpm and don't idle down for about 3 seconds. Not sure if that has anything to do with it.
Moved from a reply to new thread.
