02 gmc jimmy Trouble fueling?
Hoser
At the pumps i can only put a litre or two of fuel before the nozzle kicks out as if the tank were full, but i know its not even close. I can fuel from a gas can without a problem. As well my gas gauge is not reading correctly i'm sure the two must be related. The engine code says EVAP system, wondering if anyone can point in the right direction to fixing this.
Was the code from the check engine light P0449? Change the vent valve $20.00 from the local dealer. Its a simple project usually , one plug , one hose and it only clips into place but it is on the frame near the spare tire . Mine did have a broken wire on the plug but I replaced it any way. This will cause refueling issues sometimes and throw the code I . Hope this helps and keep us posted:rolleyes:
