04 Sierra a/c not cold
Hilife922
My 04 gmc Sierra a/c does not blow cold. I have replaced the high pressure switch. The coolant level is good. The compressor kicks on and off. Makes a funny noise and seems to operate "slow"? fuses are all good. Low pressure switch is good. Compressor comes on quietly. Not sure what my problem could be? :confused:
It sounds like you have a low refrigerant charge. For about $50 you can buy a cheap set of gauges and check the pressure when the compressor kicks on. For about $30 you can get a recharge kit with a low side gauge. It'll tell you the suction side pressure only. I've used them in a pinch.
