04 Sierra Electrical Problems
pappy56
South East Texas
Driver side window and door lock controls quit @ work then on the way home warning lights & radio started randomly turning off and on. Found that negative post of battery had corroded. Cleaned battery post and all ground wire connections to the engine block and truck frame (read about bad ground connections causing problems).
Thought that would fix problem.. but driver side controls still don't work plus
dome lights go out the moment key turned to off and truck will not start occasionally. Truck runs fine when it does start! Also noticed today that
running lights turn off when truck is put in park.
Any ideas .. is this some how tied to the (BCM) body control module.
Scheduled a visit for diagnosis Monday with Dealership but would like to figure
this out before they get deep in my pocket book.
Thanks
Pappy
