06 siearra slt
25431
06 Sierra SLT
What size, if any, lift would i need to put 17" moto metals w/ -12mm offset on my 285/70-17 bfg AT's? The tires only have 4,000 mi on them but i'm looking to upgrade from stock rims.Torrsion bars are cranked all the way, just wondering if the tires will rub without a lift. Any help would be appreciated
You should be fine on doing it if you cranked the torsion bars.
Here are the specs to your tires.
Original Equipment Sizes for 2006 GMC Sierra K1500 4wd Crew Cab
Specification Sidewall Radius Diameter Circumference Revs/Mile Difference
245/70-17 6.8in 15.3in 30.5in 95.8in 661 0.0% GMC Option 1
265/70-17 7.3in 15.8in 31.6in 99.3in 638 3.6% GMC Option 2
285/70-17 7.9in 16.4in 32.7in 102.8in 617 7.2% Difference from Option 1
17x9, Front Mounted Cap
Offset: -12mm
Backspacing: 4.60"
Bolt Pattern: 6-139
Rec. Tire Size:275/60-17
Optional 18" rims for your Sierra
18x9, Front Mounted Cap
Offset: -13mm
Backspacing: 4.52"
Bolt Pattern: 6-139
Rec. Tire Size:285/55-18
