In simple terms which is about all I can offer, There is No direct mechanical connection with the engine, its drive by wire. You push on the pedal and a electrical signal is sent to the engine for fuel. I been driving them since 2005 as my CTS has it back the. If this is the first vehicle you have with Drive By Wire then you will find it take some getting used to as there can be lag time from when you step on the gas to when it moves. Also depending on driving conditions the 6 sp trans could be hunting for the next gear at the same time you are slowing down.
I found it took some getting used to and it no longer bothers me.
2010 GMC Sierra ECSB SLT Z71 All Terrain 5.3L 3.42 G80 Axle
2009
Cadillac CTS4 AWD Performance Sedan 3.6L VVT
