I have to let my truck warm up for 15 minutes in the winter time before I can drive it. If I don't then it will die when I give it gas. Not as bad in the summer. A few seconds and I can start putting along. I am thinking vacuum leak but I haven't found any obdvious ones. It also shifts very quickly through the gears when you aren't pressing down on the pedal harder, and sometimes doesn't down shift to first a stop, and then starts out in second. this only happens sometimes. I replaced the vacuum line that feeds the transmission and it didn't help. I haven't done a vacuum check but it sure seems like it's just enough to make everything work. I did notice that the very top flap on the carberuter is held open by a wire. Not sure if this will cause my problem or why it is not hooked up that way. Can someone give me some ideas to what I should be looking at?
transmission fluid and filter were changed 6 months ago.
