W williamkline New member Joined Jul 11, 2013 Messages 2 Reaction score 0 Points 0 Jul 11, 2013 #1 I have a 1988 jimmy with a 5.7. I need a new fuel tank. my question is will a fuel tank from a 1988 jimmy diesel 6.2 work in my jimmy?
1 1988IndySierra New member Joined Jul 7, 2013 Messages 40 Reaction score 0 Points 0 Location Austin, Tx Jul 11, 2013 #2 No, because the gas truck uses an in tank fuel pump and the diesel does not. Unless you are running a carb, you will need a tank for a gas powered truck. Below is the interchange. BLAZER/JIMMY (full size) 87 gasoline, 31 gal BLAZER/JIMMY (full size) 88-91 gasoline SUBURBAN 10 87-88 gasoline, 31 gal SUBURBAN 1500 87-91 gasoline, 31 gal SUBURBAN 20 87-88 gasoline, 31 gal SUBURBAN 2500 87-91 gasoline, 31 gal
W williamkline New member Joined Jul 11, 2013 Messages 2 Reaction score 0 Points 0 Jul 11, 2013 #3 ok thank you for the information.
