1990 4x4 sierra stepside
bucketZ71
Age
40
clarksville, tn
im looking at a 1990 sierra 4x4 stepside with a 350 on a 6in spring lift.
what are some of the things i need to look for?
are there any main problems with this type of truck?
Used vehicles
Check for leaks around engine mainly water pump, intake,oilpan, rear main. If this truck is a project these r minor repairs if this truck will be a daily driver these leaks could cost u in the long run if overlooked . Also outer rear axle seals leak and rear brake cylinders . Check the oil very carefully in a well lit environment look cleaness of the oil rub the oil on a white sheet of paper look for shiney particles or metal dust chocolate milk look means there is water in the oil could have cracked head or bad intake gaskets . Drive it I can already tell u the front end will be worn out . Check for slack in steering , pulling don't be afraid to drive it like u stole it . Listen for howling in rear end. Put in 4wd make sure it works . Also take a friend along to double check u. All these things are critical and could greatly affect the price. Let us know what u find
