1991 GMC Safari won't start
Deadly Sones
Hello everyone, new guy here...
So here's the story...
I bought this van (1991 4.3L safari) on tues... when I went to see it the owner started it. It didn't fire right away and did run rough but it started. Owner removed batt. It has been sitting for 4 years. Has half a tank of old fuel in it.
I have it towed to my place on fri and install a new batt. Try to start it, with no luck... :( It turns over and every now and then will fire one piston but that's it...
I thought maybe bad gas so I added some gas line antifreeze to the gas tank and tried some quick start on it... same results
Then I noticed the distributor was loose so I verified timing. Good.
I thought possibly the ICM was bad so I bought a new one and a new coil even though I have spark) just cause rust was starting to break it apart. Still no luck...
After while I figured I flooded it so I pulled the plugs out for the night. What should I try today?
I really need to get this thing going this morning... the way I see it is I have spark, fuel and air... what else is there?
Smokey_Beer_89
i would drain the old fuel cause allot of water will be in the fuel sitting for 4years with fuel in it,
