1992 suburban k2500?
k2500
hi guys
first i have 1992 suburban k2500 the degree of the engine goes high and i have some question :
you thinks guy i must put electric fan or not ?
what is The best viscosity of oil for engine ?
i am sorry if don't you understand some word because i 'm not good in english
hi guys
Start with the simple and flush out your cooling system with radiator coolant flush and replace your thermostat.
As for your engine oil viscosity, follow your owners manual. 10W30 is a good all round viscosity for the year of your Subrurban. newer engines run on lower viscosity oil for better milage and sensor readings.
Good luck and keep us posted.
doesn't work
still the engine temperature goes high
you think there any thing else i can do it ?
more info
Does it get high when driving down the road? or at idle ? or only on the highway? hot days or cold days? Does it have heat in the cab when this happens?
get high when i'm driving down the road and idle
but in highway it's good
just in hot day
the temperature in hot days always between 35_58 degree
what you think about electric fan ?
