1993 sierra will not turn over/start
93sierra6cyl
History - 1993 sierra 6cyl Automatic- truck has been having issues starting and running for a month or so. the other day I started the truck fine, but I could not shift into any gear and could not turn the key off. After messing with key finally got it to turn off, started truck again and was able to shift gears. (this happened twice in the same day). I got home, turned off truck, a little later went to move truck and it would not start. All lights work but it does not turn over. I tried putting in neutral, nothing. I tried wiggling shifter, nothing. Battery is good. Any ideas what I should try first? Neutral safety switch, starter, ignition switch????
Thanks
