Hello, could anyone tell me to what torque spec I need to tighten the water pump connector bolts? Also, should I torque the fan/clutch assembly to the pump to a specific spec or is TIGHT good enough for that part?
Lastly, the car has been sitting for 8 months without a busted radiator, I did a "poor man's" flush by sticking the garden hose into the outlet from the water pump and catching the crud that came out, will that be sufficient to clean out the cooling system? rad/pump/fan are all being replaced.
Thanks in advance,
Mike
Thanks in advance,
Mike
