GregGarage28
Hello my name is Greg.
Would anybody know why a freshly rebuilt 350(5.7L) would surge at idle? That is to say when you open the throttle and let it close the rpm will go up and then come down and almost stall then return up to normal(600-750) rpm level. Also When engine is cold it seems to want to almost stall when rpm drops after gear shift(truck has 4L60E). Could this be related to an oxygen sensor, idle air control valve, coolant temperature sensor? No check engine light has ever come on before or after engine was rebuilt. this also happened before the engine was rebuilt. also the mileage has gone down 150kms per tank since rebuild. Any insight would be greatly appreciated.
Thanks,
Greg
Thanks,
Greg
