i got a 96 with a 4.3 i replace the head gaskets and the intake gaskets i torqued the heads like it says and the passenger side of the intake is still leaking?? any answers would be helpfull...
Did you check to see if the intake is cracked.???? Recheck it and replace if it is cracked. The other issue would that you over torqued the intake and crushed the gasket.
Remove the intake and inspect it and replace the gasket. Good luck and keep us posted.
