My jimmy is not engaging the front axle. I have replaced the vacuum lines and checked that the actuator is working (which it's working perfect). Checked that the front driveshaft is spinning while locked in and it does. I pulled the actuator cable from the differential and it is moving fine down there on the differential. Plugged a compressor into the vacuum line at the actuator on really low pressure to check for any leaks and didn't hear any, unplugged the vacuum line from the transfer case and could hear it coming out and no atf came out either. Any other ideas about why the axle is not engaging? Thanks in advance!
