1996 GMC Jimmy SLT 4×4 Center Link Hole Taper Angle
cyphercrash
I have the Center link that is just a steel bar with 4 tapered holes. Does anyone know if the tie rod holes have the same taper angle as the idler arm and pitman arm?
cyphercrash
Answer chassis unlimited makes inserts for the 1996 and up 4x4 for the centerlink so you can fix the walleye holes in the link fromfrom wear
