1996 Jimmy SLE transmission issue
clyburn3
While driving down the highway the RPMs jumped from 2.5 to 3.5 and then when I shift into reverse, the transission will not engage. I have added Lucas gear slip/leak repair and transmission fluid with no change. Is there any other troubleshooting that I may able to do myself before taking it to a repair shop?
Thank you in advance for your assistance!
That range of a jump sounds like the transmission "riding the clutch." I've noticed the truck do this on highways instead of downshifting.
A few weeks ago, I had a similar experience while I was towing a trailer and Tow/Haul was engaged. The transmission is not supposed to do this while towing but it was anyway. In fact, RPMs were jumping wildly while going uphill as it disegaged and reengaged the torque converter. However, this was not a transmission problem, nor do I think your problem is.
I know very little about how our transmissions work, but I think I can point you in the right direction. I'm pretty sure the transmission is controlled by the computer, not a separate controller somewhere. See if you can locate one for a good price. I was able to find it on rockauto.com for $168, with a $75 refund for the core. Probably the best price you'll find on these. But you probably want to verify some of this first. I'm no expert on trannies, this is just my opinion.
I am having a mechanic check out the problem and I really appreciate your feedback.
Sounds like there is a good chance that the Sunshell is broke. Revers may or may not engage and 2nd gear will be noisier then normal.
Keep us posted and try not to run or drive the car or further damage could result. Good luck:eek:
Molson02536;)
