1997 Jimmy won't start
jaa1971
I have just replaced the fuel pump which had gone out, but now it will only turn over and not start, even with adding a little fuel into the throttle body. Not sure if I am getting fire at the plugs, gonna check that next, but thought I would go ahead and post this now. All fuses are good.
Fuses are good, check the fuel pressure at the shredder valve and test your ICM for a start. You can have your ICM tested at most auto parts store like Auto Zone or Parts Source for free of charge before you buy the replacement ICM.
Good luck and keep us posted;)
before you remove anything.............. Just simply check and see if you have spark or not. Check fuel pump turning on with your ear. Did you replace the fuel filter ? Is it pluged?
see what you missing before you take anything apart and have it tested.:rolleyes:
