C Corey New member Joined Jun 25, 2010 Messages 2 Reaction score 0 Points 0 Jan 4, 2011 #1 wont switch truck into four wheel drive? i have checked all fuses and think its a wiring problem how do i tell and what wires would it be
E el_oso_candeloso New member Joined Jan 4, 2011 Messages 1 Reaction score 0 Points 0 Jan 4, 2011 #2 your switch is bad or you can also check if all fuses are still good. if all are, you swtich is bad and can be easly replaced. junkyard or aftermarket is the most affordable.
P POKE New member Joined Apr 27, 2010 Messages 2 Reaction score 0 Points 0 Jan 4, 2011 #3 It could be as simple as the switch just went bad. hope that helped some.
M Molson02536 New member Joined Dec 9, 2009 Messages 3,123 Reaction score 0 Points 0 Location K/W Ontario Canada Jan 4, 2011 #4 Corey said: wont switch truck into four wheel drive? i have checked all fuses and think its a wiring problem how do i tell and what wires would it be Click to expand... This post should help you. Keep us posted and keep us updated. http://gmcowners.com/gmc-forum/showthread.php?t=16509
