you've got a burb too, sweet.
not sure if your model has a cabin air filter but if it does it may be time to check it. a cabin air filter filters out all incoming air before it enters the cabin. if this gets clogged it will reduce the amount of airflow going through your front evaporator. your rear unit does not draw air from the outside, hence it does not have a filter. so that's gonna blow cold as long as the refrigerant lasts.
another possibility is your front evaporator is clogged, be it leaves or bugs all this CAN get sucked into your burb. first thing it hits is gonna be your evaporator. or if you have your heat on it will hit the heater core first.
start checking the small things first: cabin air (if equipped)
refrigerant level (gauges found at most local auto parts stores) follow the directions on the gauge some ask that the vehicle be running some don't. if its low refill it. using R-134a your capacity should you need it is 57 oz
after that, if you feel comfortable ripping your dash apart you can check to see if your evaporator is clogged.
this step may best be left to a pro as they have insurance to cover any damage they cause and the tools to do the job right.
