1999 K1500 3rd cylinder misfire
noahjt
I had a 3rd cylinder misfire a few weeks ago, started small, worked my way up. Plugs were changed last year, changes the wires and didn’t resolve. Did a primary and secondary test on ignition coil, both resistances were within the range. Finally changed the rotor and distributor cap. Misfire resolves and check engine turned off.
A few days later at idle I noticed a slight shaking. Check engine light is back on and the shaking is more consistent. It is much worse when the engine is cold. I now have a P0303 as well as P0174 fuel system lean code. Has anyone else had this problem or have any advice?
Thanks I’m advance
Kamfith
Panama
The Ehgine Emisions light comes on. Once the car has been started 4-5 times later the light is off.
Going to book it into the garage to get looked at this week
If you have virtually any queries about wherever along with how to employ What are the negative effects of violent video games or How much memory did the original Xbox have, you are able to call us on the web-site
