overlander64
- Jun 16, 2011
I special ordered this Suburban in 1998 and took delivery on April 21, 1998. Today, it has covered 199,000 miles with a good portion of those miles towing my 6,100 pound Vintage Airstream travel trailer. Some basic facts about this truck:
This is my third vehicle with four-wheel-drive and the second that I purchased brand new. It is equipped with what is most certainly the most troublesome four-wheel drive mechanism. The $750 Lucas Electric Transfer Case Control Module has been replaced close to one dozen times and has meant that the four-wheel-drive has only been operational four times when it would have been helpful.
When four different repair shops concurred that boh the transfer case and control module need to be relaced at this time, my reaction was absolutely not -- remove the thing entirely and make it a two-wheel drive. The shops discourage this, but I can't imagne that it would cost much more than the lowest estimate of $4,385.00 to replace the transfer case (remaufactured) and control module (new). A new vehice is out of the question at this time, so I must get this one repaied -- the body and chassis has virtually no rust and both the motor and transmission perform flawlessly. My question is: "What would be involved in disabling/removing the transfer case making the truck strictly two-wheel-drive??
Thank you for your input!
Kevin
- 7.4 Liter VORTEC V8 motor
[*]Timing Gear and Chain replaced at 188,000 miles.
[*]Rear Main Seal and Flywheel replaced at 190,000 miles.
[*]Regularly serviced by GM Dealer at 3,000 mile intervals. - Automatic (Push-Button) Transfer Case
[*]Lucas Electric Transfer Case Control Module First Replaced at 35,000 miles.
[*]Lucas Electric Transfer Case Control Module Replaced at 8 to 14,000 mile intervals thereafter.
[*]Most Recent Lucas Electric Transfer Case Control Module Failure 198,000 miles (was locked in 2-Hi).
[*]Diagnosed with Failing Transfer Case Requiring Replacement.
[*]Transfer Case Totally Failed today at 199,000 miles. - Differential Gearing of 4.10 from factory
- Limited Slip Rear Differential.
Kevin
