1999 Sonoma Highrider
subgeniuschick
1999 Sonoma Highrider - ignition switch
I'm trying to replace the ignition switch. I've managed to remove the torsion screws holding the steering column cover on, but I still can't remove it. The bottom is being held on by the tilt steering lever and I can't figure out how to remove it short of breaking it. The top is being held on by something I can't see close to the steering wheel.
HELP!
HELP!
I just replaced an ignition switch on my g/f's 00' blazer a couple years ago and No, the steering wheel doesn't need to be removed. Also, I did not have any issues with the passlock system when I replaced it. Lastly, I bought the switch at Autozone for about $70-80.
Here are couple of tips:
Make sure you disconnect the negative battery cable and remove the airbag fuse before working around the steering column wiring. I believe you are suppose to wait about 15 minutes after disconnecting also before working around the electrical.
Pulled the front of the instrument panel off that holds the air vents, rear window and 4wd controls. I pulled it loose (by pulling towards you if you are sitting in the driver's seat) and then used a bungee cord to the rearview mirror to help keep it up an inch or two. I found I needed to do this to remove the top steering trim piece.
The hardest part of this job for me was removing the trim around the ignition cylinder! When removing the trim around the steering column and ignition, there are tabs in the back and two screws that connect the top and bottom pieces together.
Also, there is a bolt that holds the top trim piece to the steering column itself. You need to look from under the steering wheel next to the ignition cylinder to see it. Once you remove it and have the dash pulled out, the top piece will come off and then the bottom piece.
When you pull out your old ignition switch, note the location of the white "gears" on the portion of the switch that goes to the steering column / ignition cylinder. Match the gears on the new switch to the location of the gears in the old switch.
Install the new ignition switch and test your key to make sure it turns to all locations (accessories, on and start) before reassembling everything. The last thing you want to do is put everything back together only to learn that your key doesn't work right. If something doesn't feel right (mine didn't go all the way into "accessories" the first time), then pull it out and check the gears.:eek:
Good luck and hope this helps. ;)
HELP!
A little update:
I found this link http://www.stolenandrecovered.com/howto/gmmulti.php, which was greatly helpful.
The tilt lever came off easily, I was just too chicken to yank on it before reading the above link.
There's a torsion bolt holding the top cowling on. Unfortunately, I don't have a torsion wrench. So that's pretty much the end of that. I was hoping to get that off and pull the cylinder so I could check the ignition switch.
Additionally I was told to check the starter solenoid - I'm still reading up on that one. It looks pretty simple to remove :o
