ISLANDER914
- Oct 4, 2009
I have been chasing this shimmy for too long and could use some help. Recently have replaced all tie rods, both cv jpints, upper and lower ball joints, rotated and balanced tires, front end allignment, pads and rotors and still have what seems to be a shimmy and higher speeds (65-70 mph). At lower speeds I can hear what would sound like a wobble hum of some sort or like a tire wear sound. Sometimes at really slow speeds, like in parking lots, when turning slightly to the right I feel the steering wheel do a little dance back and forth. I tow a travel trailer with a weight distribution hitch and not a peep. I tow a 16 foot bass boat and at 65 mph you would think the front end is coming apart. Mechanic checked idler and pitman arm, said they were good. No play in wheels when it's jacked up. Can it be a bad bearing or a bent axle part of some sort? Bought it used and it currently has 170K miles on it. Any help is much appreciated. Thank You.
"IF YOUR NOT DRIVING A SUBURBAN... YOUR NOT DRIVING"
